You have to open your drivers door and it is behind the panel to the right of the steering wheel facing the door. bugger to get off... even worse to get back on due to the rubber seal... if you take off the cover for the ODB (OBD ?) port then you can put ur arm in to push on the cover to make it easier to come off... be careful though.
