Interior Door Panel on mk2 Ibiza
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
slowly, carefully... use a thin long blade (like a spatula ) if you can find one.. although its not really the door panel you need to worry about, if its never been off before, you'll probably end up having to cut the plastic door liner to reach the lock etc
:D
paul geraghty
Das Booted Brigade
drilled and now fitted the new lock although had to swap bits from the old one over as the bar that connects to the inside handle was longer on the new one.
btw there is a few bits left on the car I took it off its over in Upton on Seven it has rolled forwards tho its on ebay
