Intercooler fitment time?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
to be honest with the leon most of the time was spent gewtting the bumpers off, actually fitting the fmic wasnt that difficult or time consuming.couple of hours, give it 3 if you arnt familiar with the bumper removal.
Jonzy
Getting the strips out is probably the hardest bit, and id cut the orginal pipework out from the inlet side of the intercooler, saves having to unbolt the subframe.
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
as Jonzy said, cut the original intercooler pipework where the instructions say to drop the subframe. I also had to trim the bumper alot, jonzy however didnt, seems to vary depending on the car
bbsboy
89
Most of the time i had was to trim the bumper, everyting else lines up nicely and fits well, except the bumper, had to trim about 1" off it
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
I have fitted 2 Forge kits now, really easy. Removing old pipe work is probably the worst bit cause you have to drop the subframe a little bit. Bumper trimming is minimal. I didn't cut the old bracket off, i bent it upwards out of the way.
