Intercooler Advice Needed Please
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
i have a custom map on my car specifically for the mods i have and im currently running at 215bhp, with summer coming i know that with my standard SMIC im going to see loads of heatsoak so i want to get a Front Mount, can i do this or will it clash with my map as it hasnt been mapped with an FMIC in mind, surely it will just aid intake temps and will just keep the temps low? hard to explain but surely running a FMIC in the summer is like running a SMIC in the winter - its only going to affect temps - nothing else?
Nov 2, 2004
9,335
South Wales
Wont make a difference. And i very much doubt your map is specific for your car either, its probably just a generic map tweaked a bit for mods.
Wouldnt worry about it.
jsparks
you will only see benefits with an FMIC, lower temps = less timing pull = quicker car
Required a battery reset after fitting but after that you wilkl notice a nice difference.
you will laugh at the size of the standard SMIC
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
it should be able to run optimised if induction temps are under control. this is std bosch ecu control... its winds settings back when it see too high a temp, so if its all under control temp wise, it will run consistently.
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
could you put that in easier terms as im pretty thick! so do you think itw ill be ok Bill? Its just a lot of wonga to spend if its not going to work for me!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
it will help, especially when the warmer weather comes. std SMIC just is'nt up to it.
you wont need to adjust mapping, ecu does this itself
in simple terms... Yes ok - do it
:D
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
thank you for your quick answer Bill!
I also now have it in writing, so when something goes wrong you can sort it out for me! :whistle:
thanks!
