Intake air temperature sensor g42 - fixed
processpaul
103
Brighton
Hi all
Had the following fault code on my 2005 1.9 tdi. Changed the Map sensor and fault remained.
16497/P0113/000275
Contents [hide]
1 16497/P0113/000275 - Intake Air Temp. Sensor (G42): Signal too High
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
I have VCDS and logged sensor and it read 134.6 degrees all the time.
Fault was caused by two wires from the MAP sensor that had broken that we're rubbing on the main starter motor cable. Garage removed air filter housing and worked his way along the wiring.
Sorry no pics as went to garage due to time.
Hope this helps someone.
SWANSWAY CUPRA Dealership
