Injectors
Olly20VT
1,234
Stroud Glos ,England
Just wondered with the mods iv got + ko3s 4bar FPR and custom code, would putting bigger injectors help atall? or maybe a bigger MAF housing or is that only if your going above 250BHPish
I know it is needed when going up the moded ko4 rought
All my mods + new ones should see 240BHP
If not injectors then what else would be the next step in engine mods for me to get more power with out costting loads and not a bigger turbo? or is ther nothing?
Maybe aquamist?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you won't get more power from bigger injectors.
All you'll do is overfuel the car is the map expects std injectors.
Olly20VT
1,234
how about if i fit the injectors then get the map? or are the std good enough?
up to what power are they good for? as i wouldent want to run them on ther max limit and if there is any power to be had i wouldent say no.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you can see on vagcom what they're flowing like - ie what the maximum injection on time is (as a percetnage) 85% is often seen, and is fine.
BIgger injectors only needed if more air is coming in. and it's not.
Jonzy
Whats the score with using aftermarket management with the cupra - dta, omex autronic etc.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
u could, but why bother as its cheaper to just remap using the regular methods i.e revo stage2/3 or custom code...unless u fancied something out of the ordinary like s/c the ickle ibiza
