Fencer60
102
69
Meon Valley, Hampshire, UK.
On page 114 of the latest version of the manual, it says:
The position memory system must be restarted if, for example, the driver seat has been changed.
Restarting deletes all memories and assignments for the seat with position memory. The memory keys can then be programmed again.
- Open the driver door and do not get into the vehicle.
- Operating the seat settings from outside the vehicle.
- Tilt the backrest fully forward.
- Release the control to set the angle and then press again until an audible warning is heard.
Has anyone ever actually got this working per the instructions? I feel like I’m missing a trick somewhere. I got some weirdness going on with my seat and want to see if a reset makes any difference.
TIA
Not sure I understand your question but if my gf has been driving (memory seat button 3). Before I get in I press button 1 and it automatically adjusts for me at the one press (and let go) of button 1.
However if I reverse the above, ie she wants it in her position, it won’t automatically move forward until she is sat in the car and then presses and holds button 3.
By initialise, I mean reset all of the memory settings, which the manual implies can be done.
The instructions above don’t work for me on my VZN, and they didn’t work on my VZ2, either.
Pretty sure it’s a user error on my part and I’m missing something obvious, though.
for anyone that pretty much gave up on this like i did, i managed to fix it.
Had all but given up on the 'moving the seat to its extremes' method but gave it another go.
1. ignition on first setting.
2. stood outside the car
3. cycled the seat forward all the way
4. tilted the seat back all the way
5.pushed the seat down all the way
6.full extension of the lumbar setting forward and down
7.reversed all of that the other direction to the extreme
did it about 5 times. I never heard the ping sound that people talk about but when i went to use the memory setting success!
^^^^ Putting a marker on this topic.
I bought my current Ateca VZ3 back in August at six months old and found the seat memory function did not work.
Tried everything per the Owners Handbook including the reset instructions quoted above; no 'ping', as I used to get in my VZ2 and preceeding VZ1, and memory function still not working.
I'll give the all directions, multiple times method suggested by @Jimbo a go in the next day or two and report back.
Guy
Sent from my Galaxy S25 Ultra using Tapatalk
There is a software update that covers this issue.
I like the sound of this, James.
I'd discussed it with my dealer a couple of months back and, rather than booking it in for a special visit, we agreed to leave it until I book a service visit. This will now be in about six weeks time.
Guy
^^^^ Cheers, James.
I'm sure the good folks at Seat CUPRA (now Renault Dacia) Letchworth will know what I'm on about when I see them.
Guy
Result!!
All sorted this afternoon; first time I'd had the opportunity to spend some time on the issue.
I adopted @Jimbo's method of;-
2. stood outside the car - but left the key in the car on the gearlever gaitor (negating the doing, doing, doing warning of the key being out of the car)
5. pushed the seat down all the way
6. full extension of the lumbar setting forward and down
7. reversed all of that the other direction to the extreme
Did this, as above 1 - 7, through just twice, and adjusted the seat to an approximate position that I'd use.
Press/hold the 'SET' button for a count of five, pressed the '1' button and 'PING'. Moved the seat a bit in a couple of directions, press/hold button '1' and the seat moved back to the preset position.
I then moved the seat into the approximate position that my partner will use. Press/hold the 'SET' button for a count of five, pressed the '2' button and 'PING'. Seat position set.
Press/hold '1' back to my position, got in the seat and fine tuned it to the position I want; Press/hold the 'SET' button for a count of five, pressed the '1' button and 'PING'. Seat position set. :D:D
Job done and inside the house for a mug of coffee to warm up. ;);)
Guy
PS> To reiterate; this is on my '74 plate MY25 Ateca VZ3
