info oil cooler for tfsi..
cupra-tfsi
31
hi guy,
do you know where i can find an oil cooler kit for my tfsi engine? (and a good price if is possible)
:cry::cry::cry::cry::cry::cry:
GolfRS
56
I know HKS makes one but its PRETTY EXPENSIVE....
There are also some kits on ebay that might work, but never heard anyone have them.
Why would you want to change your oil cooler ?
Are you seeing excessive oil temps ??
Better cooling for oil is good, but excessive cooling is NOT better...
Not sure if the Leon displays the same info in the DIS but my "normal" oil temps are around 90-95 deg C rising to 105-115 deg C when driving hard. Thes isnt excessive in the slightest and wouldn't pose a problem unless your in the UAE etc!!
If the Leon dosent show this information in the DIS, you can always log with VCDS to check and see where you are.
GolfRS
56
I agree.This was my reasoning also.
Most tuned cars see temps in the area of 100 to 115 C.
If you are not beating on your car or tracking, there is no reason for an upgraded cooler....
