Induction Kit Fitted, Spare Pipe/hose.?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Fitted a inducton kit last weekend ( pipercross) all fitted fine and pleased with it, but when i finished fitted it i noticed there was a hose/pipe that connected to the factory air box and went into the back of the engine at the bottom but there is no where for it to fit on to on the induction kit.? to me it seems a greenie color and a soft corrigated (spelling) kinda of hose if you get what i mean lol. i brought a pipercross breather filter but i dont think it will fit because the apperture size of the pipe is around 40/50mm and the filter is around 18mm. does anybody know or have anyideas what i should do because im worried its going to suck in crap and do some damage. the car seems to be holding back alittle now but that could just be me.
greenmachine
HoK'd GreenMachine!
Sep 21, 2005
87
Kerry, Ireland
www.cruiseirl.com
I may be totally wrong, but it may be the oil breather pipe... Get an oil breather filter to go on the pipe... Im not that mechanically minded but I think an oil catch tank works to for it, it brings back the left over oil back to the engine.. connects to that I think.. The more technicly minded should be helpful.
I've a left over pipe from the old airbox connected to an oil breather filter,,
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
the pipe you're talking about is the warm air pipe - goes from the exhaust manifold to the air box - so your car starts better when cold.
but you've disconnected it, so don't worry.
Mckellar
that stopper looks really good, where did u get it from because i have the same problem, its just looking a bit horrible sitting there open pipe and dirty :cry:
also need to buy a new oil breather i popped the bonnet last week to fill up screenwash and found out it must have fallen off grrr
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I might have a pipercross one for sale if you wanted it never used, thats only when i know i cant use it on mine.. let you know before tuesday :)
Mckellar
sounds good thanks, i have a piperx on my car as it is
ibiza_95
1.8T MK2 Conversion
ha.
the stopper is just a lid off a jar which i thought would look ok, and then just pretty much jammed it onto the pipe. i sand blasted the cover at uni and then just painted it with hammerite. i had the lid off a t-cut bottle or something like on before and that looked loads better but i think it fell off somewhere.
your best off getting an oil catch tank instead of a breather filter. although they do seem expensive at first, the breather filter gets clogged up and needs replacing every so often so in the long run it probably works out cheaper
Mckellar
nice idea man, just shows what u can do if you put your mind to it :happy:
justinking
136
i bought a pipercross for my cupra aswell, and it definately slowed it down, without a doubt, was so much slower.. so took it straight off, maybe something to do with it not gettin enough cold air lol
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
You will 'need' to relocate the filter from the back of the engine to the front of the engine, behind a light. otherwise, as you say - all you'll suck in is warm air.
that was phase II of my induction
Phase III was a metal case, and cold air fed from the fog lamp
Mckellar
do u think it will still be as bad if you have a cold air feed coming from under the light/underside of the car right up to the induction kit at the rear next to windscreen. i have that set up- but i may buy a new one, or re-locate it or just extend the cold air pipe.
ibiza_95
1.8T MK2 Conversion
wd40 and a green scowrer (SP*... badly too) just scrub the hell out of the rocker cover... dont even need to take it off, and the rest you just got to get dirty and clean with some cif :)
do you guys think that if i relocate my induction kit to nearer the front it would perform better?
pic of my engine is on previous post if you werent sure.
cheers
justinking
136
yeah in my engine the filter sat behind the light anyway, but just wasnt gettin any cold air, sounded awesome!!
ibiza_cupra_gti
61
i have just ordered a pipercross induction kit for mine...i was looking forward to fitting it thinking i would get abit more power and response :doh: ..so do they defo slow cupras down then? :cry:
Lukea6
Need help!
I've heard u lose torque...
I've considered drilling my airbox but can't see it making much difference. Might be wrong like!
ibiza_cupra_gti
61
well outta order that init..they told me in the shop i would defo feel a diference in performance,when it comes im gonna fit it and if its cack im takin it back lol
