Induction Kit Advice
CupraAaron
10
Hello all, apologies if this is a tedious post that has been covered more times than I've had hot dinners, although I did use the search function and didn't really find what I'm after.
I've done a few mods to my 1P Leon Cupra and the next one on my to-do list is the induction kit. I was after some advice on what you guys have used and what you recommend. As it stands, I would probably be choosing between Revo, K&N and Neuspeed P-Flo, although I imagine I can't really wrong with either of these options. They're all roughly the same price, although I can get the K&N one a little bit cheaper as I work in the trade.
Thank you in advance.
Gctdi00001
11
Hi,
I've done a bit of research into this and from what insee the best one appears to be the revo (also the most expensive) .
Lots of people use the ramair induction kits as value for money seem good.
If the k&n is an in line one I'd avoid that on the tfsi personally.
Not sure about the neuspeed!
Hope this helps :)
ChocoMilkShark
123
8
I have the ram air one and I'm happy with it easy to fit and sounds good when the turbo comes on.
Don't have any photos to show but I can grab one if u want.
Sent from my XQ-AT51 using Tapatalk
