individual ambient lighting slider coding based on a golf 8 one
Widil
108
22
Hi all,
On the obdeleven forum, a golf 8 user posted the coding (see below) to have a slider for individual ambient light coding (here's original thread)
I must say I'm too lazy at the moment to try it, so has any of you tried with any success ?
09 Central Electrics
Adaptation
Interior_light_general_settings
Automatic_ambiance_lighting_with_fpa (active)
Interior_light_hmi_config
Hmi_fpa_dependency (active)
Hmi_ambient_color (active)
Hmi_contour_color (active)
Hmi_menu_ambient_lighting (active)
Hmi_functional_ambience_lighting (active)
Hmi_play_of_colors (active)
Hmi_Display_Color_light_function: 1
Hmi_ambient_profile_1 (active)
Hmi_ambient_profile_2 (active)
Hmi_ambient_profile_3 (active)
Hmi_ambient_profile_4 (active)
Hmi_ambient_profile_5 (active)
Hmi_ambient_profile_6 (active)
Hmi_ambient_profile_7 (active)
Hmi_ambient_profile_8 (active)
Hmi_config_member_bottom_color_scheme_1: 3
Hmi_config_member_bottom_color_scheme_3: 2
Hmi_config_member_bottom_color_scheme_6: 3
Hmi_config_member_bottom_color_scheme_8: 2
Hmi_config_member_center_bottom_color_scheme_1: 3
Hmi_config_member_center_bottom_color_scheme_3: 2
Hmi_config_member_center_bottom_color_scheme_6: 2
Hmi_config_member_center_bottom_color_scheme_8: 3
Hmi_config_member_center_color_scheme_1: 3
Hmi_config_member_center_color_scheme_3: 3
Hmi_config_member_center_color_scheme_6: 3
Hmi_config_member_center_color_scheme_8: 3
Hmi_setup_set_1: 13
Hmi_setup_set_2: 7
Hmi_setup_set_3: 15
Hmi_setup_set_4: 5
Hmi_ambient_colors_bitmask: (4 51 40 AD)
Hmi_ambient_colors_fod_bitmask: (3F FF FF FF)
Hmi_contour_colors_bitmask: (4 51 40 AD)
Hmi_contour_colors_fod_bitmask: (3F FF FF FF)
Interior_light_router_config
Output_lin10_light_function_slave_3: 9
Output_lin10_light_function_slave_4: A
Output_lin10_light_function_slave_8: 19
Output_lin10_light_function_slave_9: 1A
Output_lin10_light_function_slave_11: 4
Output_lin10_light_function_slave_12: 5
Output_lin5_light_function_slave_3: 7
Output_lin5_light_function_slave_4: 8
Output_lin5_light_function_slave_8: 17
Output_lin5_light_function_slave_9: 18
Output_lin5_light_function_slave_11: 4
Output_lin5_light_function_slave_12: 5
Output_lin9_light_function_slave_2: D
Output_lin9_light_function_slave_3: E
Output_lin9_light_function_slave_6: 12
Interior_light_functions_1_to_70
Light_function_1: (active)
Light_function_4: (active)
Light_function_5: (active)
Light_function_7: (active)
Light_function_8: (active)
Light_function_9: (active)
Light_function_10: (active)
Light_function_13: (active)
Light_function_14: (active)
Light_function_18: (active)
Light_function_23: (active)
Light_function_24: (active)
Light_function_25: (active)
Light_function_26: (active)
Hmi_setup_members_set_1_byte_2: (1C)
Hmi_setup_members_set_2_byte_3: (60)
Hmi_setup_members_set_3_byte_3: (10)
Hmi_setup_members_set_4_byte_1: (C)
Hmi_setup_members_multi_color_byte_1: (C)
Hmi_setup_members_multi_color_byte_2: (1C)
Hmi_setup_members_multi_color_byte_3: (70)
