Indicators not flashing when locking car
andyc
35
Lancing, West Sussex
Hopefully someone will be able to help me.
I have a 2003 Cupra and when i lock the car the indicators will not flash to show te car has been locked. I am only pushing the button once to lock the car and the led light on the drivers door is flashing.:(
When i unlock the car the indicators will flash.
Any help/info will be gratfully appreciated.:)
Andy
andycupra
status subject to change
this is a warning that something is not correct,
if i remember rightly it will be that the car does not think one of the doors or boot is closed..?
so likely to be a microswitch in on the door locks perhaps.
does the interior light come on if you open each door?
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Mines the same, not sure it does flash??
I know the interior light switches off which shows it's locked, ( not so hot in the daylight )
andycupra
ah yes forgot, the bonnet switch is a potential other cause.
so yes, you have a problem, (the lack of flashing indicates this).
for whatever reason the lack of flashing is highlighting a security issue, which will be that the car thinks a door boot or bonnet is not secure.
Not sure where the switch is off the top of my head, but it could well be the bonnet switch. (it might be in the lack mechanism..)
andyc
35
Right sussed the problem. When i lock the car the drivers side rear passenger door is not locking.
When i open the door it sets the alarm off.
Any ideas what needs replacing or repairing?
&rew
That's what she said
Nov 13, 2006
93
Ipswich, Suffolk
I've got a similar issue with mine. The passenger door is intermittently either not unlocking or locking. When it does lock the mechanism sounds laboured. When it was on VAG-com recently there was a voltage issue warning for the passenger door. I might try the palm of the hand technique as I assume this is to 'help' a loose connection? :confused:
andyc
35
Tried giving it a bang on the handle also taken a soft mallet to the inside of the door but alas no luck.
I will have to get it put on Vagcom and see what shows up. I would imagine i am going to need a new door module, what do you think.
