Hi there, First time on here so apologies if I get it wrong.
Its a long story but to keep it brief had to replace my car quickly after my local postman managed to write it off one morning so test drove and then bought a 09 plate Seat altea xl 1.9tdi with full service history(Private sale). I paid for it it and once I sorted insurance and road tax went back to collect it and take it home but the immobilizer seems to be activated. Was running perfectly but now starts for one second and then stops. I have three keys. Two remote fobs and one solid. Had the AA out and they say its immobilizer is in SAFE and couldn't do anything to help. I have tried disconnecting battery and shorting across connectors for 5 mins to reset ecu etc but makes no difference. One remote used to operate the door locks etc but now wont unlock drivers door. It needs to be unlocked manually. Any help or advice most welcome. I have had to buy another car in the meantime as the courtesy car we were using was taken back. Can't afford to spend a fortune but spoke to local Seat dealer and they wan't £100 to just connect it to diagnose if there is a problem and god knows how much they would charge to fix it. The AA guy did check using his diagnosis unit and found no other faults or fault codes apart from the immobilizer locked which he couldn't access. Could it be the transponder chip that failed in the key? Seems an odd coincidence but after the month I have had it wouldnt surprise me.
