Hi all. I ordered a VC cable from Ebay for the basic 409.1 yesterday at about 2pm and it arrived this morning !
Now I need help because this is the 1st time I have done this. I have downloaded 409.1 from the Rosstech website and the new cable comes with a CD that says 409.1 driver. Do I need to install this or is it just 409.1 again?
Onto the next stage, do I need to have the cable plugged into the car before configuring it to Vag-Com and assigning a port?
Thanks to a very helpful dave_ph on here , I know how to do MAF logs which is why I bought this cable. I understand that I need to click 'select control module', then '01-Engine', then another button called 'blocks'? I will then be presented with 3 lines in which I need to enter a code in each i.e. 003 but which codes go in here?
After this, how do I see all of the data that it has logged? I plan to do this in 4th gear from approx 30mph.
Any info much appreciated and i'll head out and do it tomorrow.
The logs i'll be taking will be with a Neuspeed P-Flo, then next week I will do the same with a JETEX. If the readings are still down, I will replace the MAF and then retry and after that I will descreen it and see the difference. My tests should hopefully help a few people
