bigboost
right, i need some help if some dont mind as the search button hasnt helped this time.... where do i start. lol. i have no probloms with my car as such, its just iv got a bit stumped, had my car custom mapped running 15psi, and hold quite well, recently i had a small leak in my custom fmic, only audiable when cold,, anyway i tryed finding the leak but couldnt, so i went back to standard smic so i could inspect the pipes properly off the car, now with th smic my boost was all over the place, spikeing to 19 psi sometimes,lol, witch i dont know is safe on a smic,, now, i found the leak to be a split in a hose, ok, sorted that, so back to custom fmic, now boost is back to an indicated 15psi at the intake.... so why am i confused?, lol, well, would you say that my pressure drop is >4psi? now the confusing part is i thought id hook my boost gauge up to the n75 pressure in hose, pretty much strait off the turbo, and it still indicates the same sort of pressure, no more, and the gauge constantly sits 1psi with the engine off, but not when hooked up to the intake it sits at zero, now i presumed if i had a 4 psi pressure drop i should get 19psi on the gauge at turbo and 15 at the intake?, i know the gauge works ok when its running off the intake, iv ran upto 26psi at the intake on this gauge, so why would i see the same pressure at both ends???? this is why im confused, i dont want to run the fmic if i got a 4 psi pressure drop but would it be better than the smic, i also use mbc set to 22psi after the n75 to up my max boost, but i couldnt run 22psi on a smic could i??? its only a k0 turbo so i dont want to overspool it, iv been assured the compressor map says max 32 psi for these turbos so i want to keep it down so i can get a good intake pressure. any help with my confuseing sa here would be apopreiciated. this is making my head hurt, been worrying about it all day,lol. cheers
