Hi all, right i've finaly started the ball rolling with my BT conversion it's going to be a top mounted twin scroll turbo and i'm now in the process of getting all the bit's together to fabricate my equal lenght manifold, but before i start i thought i would ask you lot your opinion on a couple of things.
1. Flanges: for free i have a choice of 316 stainless steel or duplex stainless steel both are 12mm plate, i've made templates so i've just got to make a choice and then get them laser/water jet cut. I feel that 12mm is thick enough but i'm open to sugestions, if anyone has had problems and can suggest a better alternative?
2. Pipe diameter: agian all in stainless steel but as yet the grade of stainless i;ve not decided on, but i have a choice of.
A:2.77mm wall thickness with an internal diameter of 42.72mm or
B:3.68mm wall thickness with an internal diameter of 40.90mm
which of these would people recomend? or are neither very good and somebody can recommend some better dimentions?
3. Runner length: obviously they all need to be the same length but is there a recomended length or a way of calculating it in relation to turbo size etc or is it just a case of whatever you can get to fit?
Also in the designe i may include a pre turbo EGT boss, once i've got it all fabed up i plan to get it ceramic coated along with the first section of the DP.
last but not least if anybody has any tips or sugestions for the designe or fabrication process that may make thing a little easier feel free to let me know, thanks in advance Tasha.
