Ignition sequence?
tashacupra
Next up "twin scroll"
Jul 26, 2007
303
suffolk
Hi all, can some body please confime the ignition sequence on th 1.8T engine with AYP code? i was confident that i new this but i had a search on the net just to confirme and came up with all sorts of weird and wonderfull things, and i'm now more confused than when i started.:confused::hide:
tashacupra
Jul 26, 2007
303
suffolk
Thank thats spot on, i did a search for ignition sequence and firing order and got all sorts of crap and things that contradicted each other, and it was the same with cylinder number, some said cylinder 1 was the other end! so i just wanted to confirme what i thought.
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
Sorry to hijack, but can anyone confirm which end is cylinder 1 and which is 4? I presume it's the same on mk4 Ibizas as mk3s. I'm trying to help someone out with coilpacks and they have replaced the right-hand one but Vag-Com says the problem is with cylinder 1 (the left hand one?)
kriso
Jan 29, 2007
2,325
Brighton
Cheers Sharky, but I now think 1 is on the right on the mk4s. Just looked on ElsaWin and it shows a picture of the cylinder 3 coilpack and it is the second one from the left :shrug: strange
kriso
Jan 29, 2007
2,325
Brighton
Ok it seems the diagram I was looking at shows the coil pack layout from behind (the oil filler neck is on the right). So 1 is on the left, as you would expect...oops!
