Phil_beeza
461
are there any things i need to watch out for?
ecu settings being lost/any safety stuff/airbags etc?
thx
* Radio code will be required unless it's an aftermarket HU
* Clock will reset
* Miles counter will reset
* Would be wise to leave it on ignition for a couple of mins for the ECU to do a full throttle body alignment (if your is a petrol).
* ECU will have to learn fuel mixture ratio if your running on anything above 95RON
* Won't have automatic roll up on the windows. Don't know why... but just lock the car up with the key but leave it in the left hand position for 3 seconds and then it will be switched back on.
just done this. unplugged black cable first then red. battery therefore disconnected for 30 mins, connected back up in reverse. red then black. ignition on....windows....down then up. aircon/fans etc. lights all on then off. started car went for a blast down duel carrageway through the gears then home taking it easy. hopefully has worked resetting the ecu. set clock again so hopefully!! tried this on my 1.2 to see if it helps my fuel issue. thanks
Gonna give this a try Saturday afternoon, will post results. :yes:
You wont have any problems mate, Seat wouldnt design a car that goes belly up when you disconnnect a battery, its just not the done thing as its a regular maintenance item.
Sure you wil have to re-store your radio stations etc and if the ECM actually does optimise fuel mapping and things then it will do that within the first few minutes of driving anywaya and anything that does lose its settings can be redone without any disgnostics eqipment Theres nothing to worry about.
It always makes some adjustments to suit the way it is being driven, but if you disconnect the battery for long enough it will start again from a base. After a bit of driving, it will just end up at the same settings unless you also change your driving style.
You won't lose your radio stations but you will need the radio code unless you've disabled it.
those idle RPM's seem about right?
Regarding my post about the radio stations, it entirely depends on if you have the O/E radio fitted or an aftermarket one, either way it should be just fine though
