ad93022
17
Basically since I've had the car the windscreen wipers will only work on the highest speed , and will not park. The rear however works fine. Really need to get this sorted !
Been told it could be the motor
Been told it could be the body control module
Been told it could just be a relay....
Could someone please tell me what's up? :)
Can't hurt to change the relay. A replacement from ebay should be pennies. There should be a fusebox guide in the mk4 faq section. Sometimes taking the relay out and giving it a whack on the pavement can 'unstick' it. In that case I'd still change it.
I'd start with checking the relay for the reasons stated above
It could also be the switch on the wiper stalk
Ideally you need to check the MVB to see if the motor is receiving a signal to run in the lower setting.
if the car motor is receiving this signal then It sounds as if the resistors have blown that limit the current to the wiper motor in order for it to operate at the lower speeds.
I'm inclined to think it's the relay as the wipers don't park as well?
I'm going to a breakers today.. Can anyone tell me where the convenience module is in the car ?
Changed out the module.... No luck :( motor or stalk next most likely culprit?
