Hey up folks,
Met up with Pedy last night to run a scan on his car and see what comes up, I've copied from VAG-COM which fauls have came up.
He's noticed sometimes the blowers don't work, the interior light won't come on when the drivers door is opened and also the fuel gauge sometimes won't work.
Any ideas?
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - -
01272 - Positioning Motor for Central Flap (V70)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
00907 - Intervention load Management
35-00 - -
Address 17 -------------------------------------------------------
Controller: 6L0 920 930 K
Component: KOMBI+WEGFAHRSP TRW V01
Coding: 00445
Shop #: WSC 06402
VSSZZZ6LZ2R037703 SEZAZ0B0840050
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
00779 - Outside Air Temp Sensor (G17)
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00121
Shop #: WSC 06402
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 57 Komfortgerát 0001
Coding: 00065
Shop #: WSC 06402
1 Fault Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
One other thing I'd add, the "Drive Signal" and "V71 Positioning Flap" ones I get on mines at times and I don't have any issues with my car, so they might not matter too much?
Any ideas?
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
000 - -
000 - -
000 - -
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
35-00 - -
Coding: 00445
Shop #: WSC 06402
2 Faults Found:
Coding: 00121
Shop #: WSC 06402
1 Fault Found:
Coding: 00065
Shop #: WSC 06402
1 Fault Found:
