ibiza fr boot
james12
78
hello i went to my car boot with my bags unlocked car on remote, and guess what it did not open i can hear it unlock and lock but when i lift the seat badge its just as if it locked!! whats gone wrong ? ive tried with the key in lock but nothing at all....
Breezapom
mk4 ibiza fr 20vt
Jan 12, 2006
608
Hampshire
sounds like you need to take the S out as it is seized up i took mine off and sprayed some lubricant stuff and all was well after or you could just buy a spare off ebay?
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
dunno where you're based, but, maybe frozen stuck? :shrug: did you try running the engine for a while then trying again?
james12
78
in cumbria, it feels like the lock is not unlocked as the boot pull felt same as when it is locked normally, maybe the motor has gone?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
There is a small plastic clip in the lock mechanism that can become brittle and snap. It's a very cheap part and can be fitted yourself. there are guides with pics on this site.
You need to get in the boot from the back seat and remove the interior boot lid trim. then all will be revealed.
Nath.
Jan 1, 2006
8,620
16
To be honest I don't think you need pics of the clip as once the interior boot lid trim is off you will prob see the little metal rod dangling and the broken clip will be inside the bottom of the boot lid.
The guide is for removing the interior boot lid trim as there are some hidden screws.
Hold on, I'll post a link to the guide.
65coupe
I'm too old for this!
Sep 8, 2007
194
Southampton
the EXACT same thing happened to me last week. I couldn't get the tailgate trim panel off from inside as there are two screws either side of the latch which you clearly can't remove with the boot closed.
I ended up cutting an inch wide flap in the bottom centre trim panel with a stanley knife. This then gave me access to the unlock "rod" which I pulled to open the boot.
Once I took the panel off there seemed to be a black plastic ring that fitted around the lock mechanism that had "slipped" round. I moved it back and now everything is fine. I've left the flap open in case it happens again...
Nath.
Jan 1, 2006
8,620
16
Here is a link to a page on Muddyboots website
http://www.seat-ibiza-mk4.co.uk/ibiza_boot_trim_removal.htm
In order to open the boot you will need to peel back the boot trim as much as you can from inside and then get your hand inside and operate the catch that has the broken clip.
Once open you can fully remove the trim and repair the fault
Right at the bottom of that page is a pic and in that pic there is a thin metal rod (like a bit of a wire coat hanger) and the small white clip at the end of it could well be your fault.
james12
78
appriciate that will have a go on saturday first day off work for a week hurray! and a wash is in order sick off this weather salt makes a right bloody mess of car!!
