Ross_Cupra-R
86
Fife/Bristol
I've done a few searches and couldn't find exactly what im after so hope someone can help.
The R needs new ARB links (the ones on the wishbone) and im not into pay dealer prices since its near xmas.
went to GSF and then euro car parts and they only list the links with 18mm inside diameter bushes in them, they even cross-referenced the VAG number i got from vagcat (6K0411315) and it thew up the 18mm ID bushed links
So, can anyone confirm that the front ARB on a Ibiza Cupra R is 20mm at the ends?
And
If its possible to get the ARB links from anywhere bar the Stealers? if so where? and part numbers?
Cheers Folks
i got some ARB links from GSF a while ago, and they were wrong, the ibiza's have offset links, where as what they gave me weren't offset.
When i went back to GSF, they told me they couldn't get the ones i needed, but they had seen them before.. stealers only
yeah had the same at GSF, although the ECP ones are offset and look to be what i need. Hopefully they will be correct. I'll see what Daves Ibiza done when he replies to my PM.
I Recently changed my ARB links, the 1st set i was supplied by a local factor were the wrong ones but got the right ones (offset type) 2nd time round. they were about £15 per side. They're all fitted now with no probs so you can definitely get them from places other than the stealers. I also got handbrake cables to fit at the same time from a different factors and they were the wrong part too, needless to say that when I went out too fit all these parts I was less than impressed to find that none of them fitted!
Robbie: yeah the stealers are about £60 all in for links and bused etc. If the ones i ordered last night are right, then they'll be around £20 all in.
Doctor rage: just out of interest and for future reference, where did you get your links from??
the ones I got came from stig's motor factors in newton aycliffe - 01325 316566. I've just measured the inner diameter of the bush in the ones I removed and it is 19mm if that helps. the new ones were a bit of a tight fit but a bit of wd40 and brute force with a tyre lever got them to slip on.
