ibiza Cupra Help Required
Flyin Scots
46
FAR 2 FAR NORTH
I'm fitting an ibiza cupra engine ('01 AYP) engine fitted to my mk2 golf. I'm running the car from a complete ibiza loom using all the ancillaries.
I'm having a little problem with the battery connections though.
I've connected the +ve and the loom is powered giving all lights,dash, interior fans etc.
The problem i am having is that the power to the fuel pump relay is coming to the wrong pins for switching.
I have shorted across the relay contacts to get the pump running and the engine starts and runs.
I have confirmed the relay is the correct one, and that the relay is operating (tried it in another car).
I have a number of cables not connected in the engine bay (all black with crimped ends that hold captive nuts) i assumed these to be associated with the ABS, can anyone confirm this?
My question is have i missed out live connections to the battery?
I'm aware that on a leon there is a live connector rail that sits below a cover on top of the battery, does the ibiza have a similar setup?
Any advice or pics would be gratefully recieved
Cheers Andy
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ok this is a long shot, as my knowledge og engine installs is very low to say the least lol.
The fuse box on top of the battery has a metel strap on the side which attches to the +ve terminal, is this connected or even there? As im sure before when i have worked on the car and forgot to re connect this the car has failed to start.
I could end up getting my coat here lol:duck:
Flyin Scots
46
FAR 2 FAR NORTH
Ah sounds like you may be on to something there :D
I wasn't sure if the ibiza had a common live rail on top of the battery, i haven't got this part so that could be my problem.
Has anyone got any pics of the part?
Any ideas what the cables connected to this are for?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Not the best pic but the only one i could find in a rush.
Its the metel strap on the left you can see which is what im talking about.
As said this then bolts to the +ve terminal.
Flyin Scots
46
FAR 2 FAR NORTH
Thats brilliant m8, you've hit it first go :D
Don't have that fuse box at all, the cables connected to it are the ones i thought may have had something to do with the ABS system.
Looks like thats me on the hunt for parts again :rolleyes:
Thanks very much for the help, been scratchin my head for a while on that :)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Hope that clears the issue for you.
You can get a brand new part from the dealers for ~£40 IIRC.
Im on the ball today!
Heres the part numbers for what you will need:
1JO 937 617 - Fuse Holder (with fuses and all mounting bolts)
1JO 937 506 C - Retainer for fuse box
1JO 937 555 - Fuse Box cover
