dobs5
I have been suffering some bad handling problems, in a straight line the steering is very twitchy and is hugely affected by bumps in the road. Through corners it is better but still "odd" feeling.
I have had the following changed:
Front wishbones and poly bushes
Front dampers (from ECP)
Front top mounts
Front ball joints
Tracking and camber checked and adjusted twice
All associated bolts changed / torqued.
All tire pressures are correct
It feels almost like the subframe is moving - is this possible? I have always noticed some rear beam movement when driving over rumble strips, could this affect the front end feel like this?
I am running Toyo Proxes T1R's.
Any help will be greatly appreciated.
Front top mounts
Front ball joints
