VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032
Component: 1.8L R4/20VT SEA 0002
Coding: 11500
Shop #: WSC 00000
5 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Anyone shed some light on these? i dont have an engine light on but these showed up when vagcom.
Lambda sensors are probably because i just put a sports cat on, not sure on the others.
cheers
Also noticed
not sure how this happened!!
Is this the coolant temp sensor.??
Coding: 11500
Shop #: WSC 00000
5 Faults Found:
P1118 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
cheers
Also noticed
