Ibiza Cupra Brake Upgrade..
P1CK4D
70
Essex
Needing to replace my Cupra's discs and pads. Was thinking, whats exactly needed to run the 312mm Leon set-up? Not wanting to purchase Brembo's or any other 4pots as I dont feel they are needed. Cheers! :D
Mat
leon hubs for a start!
TBH, the brembo kit is probably the easiest way to go! You missed a GB a few months ago with Bill. £800 all in!
May 25, 2008
2,400
cambs
i'm with mat on this one ! i think it would be more cost effective to use the brembo set up as these did come as standard on the "r's"
P1CK4D
70
Essex
Well in that case. Just up-rated discs and pads it is then. Cheers for the quick replies. Just thought it may have been an easy swap like the Vauxhall world.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Yeh shame you missed the group buy on these... i couldnt resist and worth every penny!
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Then brembos are a MUST! Going the same route as you soon, like i said on ko3s the standard brakes felt dodgy, so there's no what they'd be up to a hybrids power
P1CK4D
70
Essex
Well i'll probably replace the disks and pads this time around and keep an eye out for a brembo kit then. Fingers crossed one comes up!
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
They do come up from time to time. Check Edition38 aswell. To be honest you could go for the 312mm setup from the Audi TT/S3, they come along alot more often and are an inprovement over standard at a fraction of the cost of Brembos
P1CK4D
70
Essex
Whats needed for the 312mm set-up as I would like to do this rather than the Brembo's
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I had this setup but never put them on the car. You need, the calipers, carriers, braided brake lines and 312mm discs redrilled to 4x100 and pads of your choice. Have a search for more info, been covered quite abit.
P1CK4D
70
Essex
Ive searched but never found a definate garanteed answer of any questions :lol:
