Ibiza crank sensor
gooders30
I've got a 2011 Ibiza 1.6 cr tdi sport and the engine management light came on the other day, and then went into limp mode, i managed to get the car home and then it wouldnt restart, I got a VAGCOM scan done a couple of days later and the car restarts and runs ok before any faults were reset.
the scan is showing 2 faults and I would like to know if it is possible to change the crank sensor myself at home and where abouts is it located
any ifo is greatly appreiciated
Monday,05,March,2018,10:26:04:54500
VCDS Version: Release 18.1.0 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 LE HW: 03L 906 023 Q
Component and/or Version: R4 1.6l TDI H33 9978
Software Coding: 00114016002500080000
Work Shop Code: WSC 131071 1023 2097151
ASAM Dataset: EV_ECM16TDI02103L906023LE 003011 (SE25)
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 74E65174DF6FCBE5A1-8020
2 Faults Found
6558 - Sensor Reference Voltage B
P0652 00 [032] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 87716 km
Date: 2074.14.05
Time: 06:26:36
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 100 km/h
Coolant temperature: 85 °C
Intake air temperature: 8 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.456 V
Unlearning counter according OBD: 40
Battery voltage: 11.3 V
Supply voltage of analog output 1-VCC_1: 5.00 V
Supply voltage of analog output 2-VCC_2: 0.34 V
Fuel high pressure sensor: unconditioned voltage-VP_PFU: 0.5566 V
Intake manif runner actuator: uncond volt actual value-V_PORT[0]: 4.990 V
Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.443 V
Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V
6110 - Crankshaft Position Sensor (G28)
P0335 00 [096] - Malfunction
Freeze Frame
Fault Priority: 2
Fault Frequency: 2
Mileage: 87716 km
Date: 2074.14.05
Time: 06:26:36
Vehicle speed: 98 km/h
Coolant temperature: 135 °C
Voltage terminal 30: 14.344 V
Engine speed: 0 /min
Vehicle speed: 31 km/h
Accelerator position: normalized-Accelerator position: 54.00 %
Battery voltage: 14.0 V
Readiness: 0 0 0 0 0
Oct 28, 2017
25
2 Faults Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 5
Mileage: 87716 km
Date: 2074.14.05
Time: 06:26:36
Freeze Frame
Fault Priority: 2
Fault Frequency: 2
Mileage: 87716 km
Date: 2074.14.05
Time: 06:26:36
It shut be located near / behind the oil filter housing.
Fault Priority: The fault requires an immediate service appointment.
However, this raises a question about your timing belt condition.?
gooders30
Hi Marty
Thanks for the info and it's a good point about the belt, it had sort of slipped my mind. Have to get it sorted!
Oct 28, 2017
25
Have a look at your engine harness for chaffing and visually inspect MAP sensor wiring too.
Another thing I didn't like was the coolant temp at 135 degrees displayed in the bottom 2nd error code.
Let us know what you'll find. Cheers Mate.
gooders30
Hi Marty
The coolant isssue is what started it all of I think, the car faulted in Dec a couple of times - temp warning light came on but the the garage couldn't find a fault with his code reader.
The prob didn't happen again til last week , this time the glow plug light came on and the car went into limp mode, then as i pulled from a junction I think I may have stalled the car and bump started at the same time?
I have used the VAGCOM to monitor the temp when driving and the car was running at around 85C ish but eventually the temp blipped up to 130C and then flicked back to 85C and intermittenly flicked up to around 135 and back, this caused the temp light and alarm to come on.
I think I'll get the temp probe changed and check the wiring/plug for any damage or bad connection.
Oct 28, 2017
25
Check your temperature sensor at ambient temperature in the morning. It shut not be far off.
Did you try your hoses on the heater exchange matrix, differences in temp? The problem with the cooling system is that the diagnostic via obd is almost impossible. Obviously, there must be a problem in your sensor, wiring, thermostat or water pump, especially if the impeller breaks. Ideally, have they measured the temperature with an infrared thermometer or something?
But again it depends, what is your level of experience?
gooders30
I got the coolant temperature probe changed and now the readings run steady with no blips or peaks.
I've been running the car for over a week now and my commute is 55 miles a day, so the problem appears to be solved, for now. I'll have to monitor the issue.
