Hi everyone i am trying to make a retrofit footwell light. i did all connection to bcm but lamp not working i am trying to code bcm with vcds but nothing changed. In long coding not have a footwell lights options, i did coding for setting option for footwell on mib screen but not lights working. Which code i need to activate. Sorry for my english
This screen looks like from ibiza commercial
I used this schema
Tapatalk kullanarak iPad aracılığıyla gönderildi
Code:
Chassis Type: 6J (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08510505150628
Coding: 11DD287D492433C4091700720058881492CC90000005E7098F00
Shop #: WSC 00049 770 00114
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 377CA6788E9960FA4D-8062
1 Fault Found:
1032 - Vacuum sensor
C10A3 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 47177 km
Date: 2018.12.31
Time: 14:31:29
Address 09: Cent. Elect. (J519) Labels: 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0084
Serial number: 001378095385
Coding: 0800084040530A7B4B844000412703500001690053010000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_VW26.rod
VCID: 306E9D646BF7B7C20C-8064
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y15M06D18H17M06S08
Coding: 00984D
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 801 CK HW: 6R0 959 801 CK Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 011 5110
Serial number: 13102697150707105856
Coding: 020000
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 6R0 959 802 CQ HW: 6R0 959 802 CQ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 011 5110
Serial number: 13102696150706205924
Coding: 020000
Drivers Door Rear Control Module:
Subsystem 4 - Part No SW: 6R0 959 811 K HW: 6R0 959 811 K
Component: J388__TSG_HL 006 5110
Serial number: 13102567150706172718
Coding: 000000
Passengers Rear Door Control Module:
Subsystem 5 - Part No SW: 6R0 959 812 K HW: 6R0 959 812 K
Component: J389__TSG_HR 006 5110
Serial number: 13202566150706215011
Coding: 000000
1 Fault Found:
922376 - Switch for Driving Profile Selection
B1427 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 47177 km
Date: 2018.12.31
Time: 14:31:43
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H08 0084
Revision: -------- Serial number: 001378095385
Coding: 010100082008560071000000000000000001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65C03C3064B5226A2F-8030
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0426290715
Coding: 002000
1 Fault Found:
1025 - invalid data record
B2005 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 47177 km
Date: 2018.12.31
Time: 14:31:29
Supply voltage: Terminal 30: 14.5 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CF770392
Coding: 000700
Shop #: WSC 00049 770 00139
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW_SE26.rod
VCID: 6DD04410BC451A2A67-8038
No fault code found.
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5QA 035 824 A HW: 5QA 035 824
Component: MU-S--ER H24 0346
Serial number: SEZAZ2R0281704
Coding: 04520000960A000011110007000908002F0301940120010006
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 3E72B35CA1A351B28E-806A
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 604 HW: 5F0 919 604
Component: ABTm_Std2 H43 1031
Serial number: SEZ8Z9RFS0053L
2 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 47177 km
Date: 2018.12.31
Time: 14:31:28
Voltage terminal 30: 14.3 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 47177 km
Date: 2018.12.31
Time: 14:31:32
BAP-BAP_Function_ID: 02
End-------------------------(Elapsed Time: 02:31)--------------------------
I used this schema
