Ibiza 6j problem with electric windows
DTomas
14
I saw a few days ago that my passanger window isn't working. Driver window works but passanger doesn't on driver's switch. I tried unplugging the door plug that leads into the chassis, when I unplug both from driver and passanger side and plug it back in the passanger switch works but driver switch for passanger window isnt working for 10-15 minutes and then dies again. I also realized when I take out the key after being in ON position "standby" mode only works for passsanger side and I can open it and close it but not driver side. I tried changing the BCM I have one laying around, I checked the wiring everything seems in order. I also had a fault code through VCDS 01332 Door Control Module; Passanger Side (J387) No Signal/Communication- Intermittent.
Any help is needed if you had any similar/heard of problems like this please link it to me.
