Hi,
I installed a direct tire pressure monitoring system (RDKS) in an Ibiza 6F (KJ) 2018 and now there is a problem
unit 5F displays the pressures correctly / allows you to change the load / select tire size, etc.
while the 17 dashboard does not display the tire pressure menu (info on car status) and when one wheel loses pressure, it displays a table (0.0)/(0.0) current/required pressure for a moment and disappears - as if could not communicate properly with the RDKS module.
do you have any solution for this?
dashboard is standard - not aid
17 dashboard sw > 0450
19 gateway sw > 0915
65 rdks sw > 0011
i have VCP - if it helps
@East Yorkshire Retrofits maybe you can suggest something
65 rdks sw > 0011
