measured my boost some time ago and i got constant 1.75bar, is this about right for 206bhp? what boost are hybrids able for constant?
faboka vrs said:But the AMD hybrid might not create as much heat as the stock PD150 running at 1.5bar. So less heat more air maybe?
micky 32 said:according to vagcom mine is around 1.75bar constant with the hybrid. Is it possible to shift more air for a given bar if the turbo is a hybrid?
prc said:I use block 3 for the MAF reading. you should be seeing a bit more Micky. Mine peaks at 1450mg/cyc.
