Hub torque settings.
conkerman
136
Hi all had a quick search but no joy.
Got my wheel bearing in and the hub is on my PD100.
I'm looking for the Torque settings for the following.
Driveshaft nut. 36mm with tabs. I have a new one of these.
Strut clamp bolt/nut.
Ball joint bracket bolts.
Track rod end nuts.
Caliper bolts.
That should do it :)
Cheers in advance.
Conks
joop200789
330
Barnsly
front hub 50nm.
Track rod end nuts. 20nm then 90 degrees
Caliper bolts. caliper carrier to hub 28nm
cant find the other two on autodata
RUM4MO
7,963
1,058
South Scotland
front hub 50nm.
Strut clamp bolt/nut. (60nm then 90 degrees)
Ball joint bracket bolts. (20nm then 90 degrees)
I've added in the missing values (from Haynes Polo 9N manual).
conkerman
136
Thank you very, very much.
Thats awesome, Just getting the other hub off and am having grief with the ABS sensor of all things :)
Nothing a few hours of WD40 won't fit.
Once again. Thanks. You're a diamond :)
Conks
