HT Leads
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Hi
Any one know the best place to buy HT leads for MK1 LCR
I take it is just unplug and replace job?
Thanks in advance
virdi
892
Middlesex
Hi. LCR does not have HT Leads as such. It has coil packs. One coil pack for each spark plug. And each coil pack sits directly on top of each plug.
Try to buy genuine or decent quality coil packs if you do want to replace them. Euro Car Parts or http://www.carparts4less.co.uk/ ....is a good place to start.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The coil pack sits on top of the spark plug. There is no wire. The wire running along the top of the valve cover to each coil pack is a low-tension wire carrying a signal voltage to the coil.
andycupra
status subject to change
as above, there are not 'HT' leads as such. If you look at the top of the engine there are 4 black plastic squares, which is the top of the coil packs. These plig directly onto the top of the spark plugs and are about 10" long?
They are about £30 each from a dealer, BOSCH is the OEM manufacturer mostly, although there are other makes.
There has been a number of recalls across the VAG range, VW and audi years ago, seat seem to have finally done the same on some batches.
GSF, and popular internet auction sites sell coil packs cheaper, but id stear clear of ordering off the net myself as many dont work if chucked about or fail quickly, much better to have somewhere you can visit to get a replacement.
If your are working, then id say get a spare one and keep it in the car. If they fail you will typically get a very rough misfiring engine, - and also likely to get a engine warning light.
Clearly there are wires which run to the coil packs, but these are not HT leads and simply plug into the top of the coil pack. if you change a coil pack take time and be careful with the wires so as not to damage them or the plug clips.
