Stumbled upon this guide to fit larger discs to the Brembo setup
http://www.drivertuition.com/LeonCupraBrakes.htm
Takes them from standard 323mm up to 330mm.
Also I'm not sure (due to the unclear phrasing) but might be able to go to 345mm?
The new disc is also 28mm thick but is a larger diameter of 330mm. These are same rotors as used on EVO and Imprezza 6pot AP track upgrade. (A larger rotor could be used, up to about 345mm.)
