How to test engine thermostat?
platofan
218
I have just bought a new one and have read you can test to see if it opens in boiling water.
All I can see when I put it in the measuring jug of hot water is bubbles, wheras when it goes into a cold jug of water I get no bubbles.
Not really sure as to what I should be looking for. Any ideas?
willives
94
Wiltshire or Spain
There is normally a rubber diaphragm which is connected to a coil/spring. When the water temp is hot it causes the coil to expand/contract and open the diaphragm and allows water to pass. When it cools it closes up and stops the water flow.
The last thermostat I tested, the diaphragm moved around 10mm.
