The engine number is stamped into the edge of the block along the bellhousing joint. Difficult to see and take pictures of. Best I can do is below.
Overview of engine bay
Detail showing part of engine number, brightened up.
Barcode label on the timing belt cover is less reliable, may not have been changed with engine.
You'll have to take the engine cover off to read it as well.
TDI 110 codes are likely to be ASV or AHF; AVG and AFN are also 110's
TDI 90's may be ALH or AGR; AHU or ALE is also possible
