Hi guys, I have the classic broken lock mechanism on my drivers door ( probably due to the classic water ingress problem. I have tried all the usual tricks to get it to open but it doesn't want to know from inside or out.
There are some great threads about how to get to the lock and open it from inside the door panel unfortuately these are all for rear doors. The front doors have 2 torqx screws at the bottom of the inner door panel( whereas the back ones don't so it is possible to get the back ones off with the door closed.
Has anyone ever managed to do the same on a front door and if so how did you get access go the 2torqx screws at the bottom pf the door?
I could try forcing it till the plastic around them breaks but I honestly don't think I could get emogh leverage to do so. Any thoughts / help would be much apreciated.
Please note the lock is fully naffed and the door is shut, I have tried for hours palming the handle locking and unlocking with the fob and manually ( all other locks work fine ) but the drivers door lock will not unlock from inside or out.
I think I know what to do of I get the door card off ( there is enough info abot removing inner panels and winding mechanisms etc but I'm stuck at the first bit of removing the door card due to the bottom 2 torqx screws.
Thanks for any advice.
Moz
Moz
