How to check battery?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Im in the same sito as you. My battery is very weak. i have a bettery tester which you plug into cigrette lighter, tells you the voltage.
If you want check your battery flud in each cell.
Big_daddy
Oct 20, 2006
3,930
Brummy
think its 12 volts, my tester just shows 3 ligths, green orangeand red. mines on orange but goes to red when i start it! My car has covered around 90k. i be need a new battery also
omg!
83
Fife
What's normal voltage?
The car is a 2001 reg, and AFAIK hasn't had a new battery since.
Normal voltage is 12.6v. if its down near 12.2v or less after the engine has been stopped for a few minutes, your battery needs replacing. It will read over 13v if you test it when the engine is running.
Go to any garage and they will test it for you, usually for free, if you don't have a voltmeter.
