Hi Folks,
My Altea windscreen washer jets are squirting all but the windscreen, I had a quick play with a pin, but it hasn`t made much difference. It`s probably just me being thick, but, do I adjust using the 2 little holes either side of the part where the water squirts out? or the bit where the water squirts out of?
The little holes either side of the jet hole (is this making any sense?!?!) only seem to be able to be moved up/down and not side to side.
Any advice greatly appreciated by me and the pedestrians I`ll otherwise soak!!!
