go on ebay and get a vw flip key with the code ending in AG. I was told to get that one and mine works fine. Get it with a blank blade (Timpsons or any other big name key cutter can cut it for about 6-7 quid). Open your non button remote and carefully with a knike or similar take the little glass transponder out of it (usually got a little bit of glue to hold it in so cut it away). Replace the transponder in the flip key with the new cut blade. Then you need to match up the lock and unlock buttons on the new remote which is simple enough using the button remote you have and the new flip key. I cant remember the exact sequence order so have a look on the
how to part of the forum which explains and job done. Phone the main stealers and quote 1mo837891ajgt for the little seat
badge to replace the VW (the screw to open the remote is under this) p.s I found the vw
badge a nightmare to get off so got the smallest drill bit i could find and from the inside drilled a little hole to push the
badge out without wrecking the plastic ring around the
badge. Bit if glue to put the
badge on with and thats it. Hope this helps
