How Low Should I Go? Pics PLEASE!
swales_p
Cupra NUTTA!!
Nov 2, 2003
278
Cleveland
Hey all, ok my car is pretty much standard bar the Magnex exhaust system but seeing as my cherished Cupra is coming out of the spray place this wed i wanna treat the motor to a new suspension set up.
Here's my problem - how low?
Im going to go the full kit but im undecided on what drop i should go for.
So....
Could i please please please have pics of Mk2 Ibiza's that have been lowered on 16" rims stating what drop, suspension etc etc there on.
Cheers :D
Mckellar
coilovers > 70mm > standard bumpers :lol:
Be careful how low you do go.
You may find your car scrapes alot and your arches take a hammering. So unless you cut your arches out or widen then then you do have certain limits.
The lower you go on coilovers the softer the ride so you will get more bodyroll and more inner arch catching potential.
I wound my coilovers back up because it was doin my head in scraping around every corner.
Feb 20, 2005
3,476
Telford ay it...
I dont have any arch problems on 16"s, just other ones
gregclarks
Trying to Resist ARBs
May 31, 2006
314
I have dropped my 16V 60/40 on Avo Road sport adjustable dampening shocks and i have only been impressed, no hassle to fit and they have not rubbed once - 60/60 would be best i think but i like my leaning forward (i am gonna ram you) stance!
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
I have just won a set of coilies on Ebay, but have been reading some scary stories about the wheel rubbing against the arch lining, where there is a moulded bulge for the airbox mount. And also the drive shafts balancing weights catching/rubbing. How low do you have to go for these symptoms to start happening?I'm planning on "only" lowering by 50mm, so will this happen to me as well?
Mig
gregclarks
May 31, 2006
314
I really dont think so mate, mine is 60mm drop and it is honestly fine, it looks the hieght it should have been originally, a standard cupra looks like a monster tuck its so high, 60mm is just right, it doesnt look 'slammed' - not too high not too low, just right
Feb 20, 2005
3,476
Telford ay it...
Mig
The balancing weight problem will be me ;)
All depends how much you wind them down mate, id say im way past 50mm so dont worry.
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Cool, cheers for that. Will probably have to take off my LCR splitter tho, and start parking outside Uni, because I dont think it will go up the Multi-story carpark. And am not sure just how speedbump friendly its going to be :cry: , so its gona be completely impractical. But it should look PHAT and handle well :D
Mig
gregclarks
May 31, 2006
314
i have never hit a speed bump and take it everywhere, dont worry so much... your car is ****ing lush already, i will upload some of mine soon, i have the same wheels did you get yours refurbed, they are mint you *******!!
swales_p
Cupra NUTTA!!
Nov 2, 2003
278
Cleveland
Cheers for the replys boys.
I'm guessing 50mm is the distance im wanting to lower by.
So..
Will i have to coilovers or is there a kit out there what lowers the car by this?
I'd look but im at work and really don't want to get caught on the net!! lol.
Cheers.
gadgetmad
The only problem I've had is damage to the sump drain plug suround.
Oh and I don't recomend any off roading, although it did a good job of mowing and ploughing the verge, when i had a blow out on the front tyre it was either the verve and hedge or the car coming the other way.!!!!:-o
gadgetmad
Personally I would recommend coilovers, because of the adjustability to suit your preferences.
Also if you damage them like I've have with my off road jaunt! they can be repaired for less than a new set of standard shocks.
Also save up for some polybushes to go with them.
I don't seem to get any body roll when cornering hard.
Mine has AVO coilovers on it.
The web site is http://www.avouk.com/pm/89
They do spring kits as well.:)
