How low on 19's?
tobywuk
83
I have a seat leon 1.9tdi stylance.
What height options do i have for lowering it? And what would you recommenced on 19" wheels?
Paulki
367
Enfield
Being on 19's shouldn't make too much difference in itself as the rolling diameter of the wheel should be more or less the same as 18's or 17's because of the lower profile of the tyre. The offset of the wheel rather than its diameter is more likely to cause rubbing problems if you lower much more than 40-50mm.
Hopefully someone with 19's will correct me if I'm wrong.
