yes m8 the bottom with the orange stripe will twist off easy enough think it needs to be turned about 3/4 of the way around before it'll come totally off
The centre part twists untill the red line further around it lines up with the one you can see on the bottom of the plug, then it just pulls off (from memory it twists clockwise to undo)
have you taken the front end off to pull it out or you taking it through the bottom of the car? i found it easier to take the front end off then pull it out on the hoist
