moditsteve
hi all i have a 54 reg seat ibiza FR and was wanting to check my side light bulb but as usuall with the ibiza everything is so hard to work on and get to. can anyone help with how is best to get to it its to tight to get ya hand in?
do u need to take headlight out or take other bits of?
I have never known such a simple job become so complicated? thanks alot steve :( :think:
im just about to do the same in my leon as far as i know you should un screw two screws on top of the lights and push the two clips out wards and case should come off, not sure if the ibiza is the same but that may help??
its very fiddly m8, just push the 2 clips to the side and take the backing cover off the magically shrink your hands and you should be able to get in there! unclipping the battery cover gives you about 2mm extra room;)
