how do i replace the gear stick
nmcdowall
i have an after market gear stick that i would like to fit to my seat ibiza, but i can't see how the original gear stick is removed. Please help.
nmcdowall
sorry about being vague, how do i remove the gear knob, from a 04' plate seat ibiza, so that i can fit a new after market one?
EdButler
713
Sheffield
At the front side of the gaiter you can sometimes feel some clips underneath the plastic (if the gaiter is not too tight). Try unclipping those first. If not i just got my fingers underneath the front peice of plastic and pulled upwards hard :p
Now the surround is loose, pull the gaiter over the gearknob and you will see a brass coloured ring with a small lip at the bottom of the knob. You need to remove this - you can use a 3mm flat-headed screwdriver into the lip and slightly prise the brass clip away. Try not to distort it too much however if you may need it at a later date.
Once that is off, you can then pull the knob upwards to free it from the shaft (oo-err!). The gaiter is held on by a small plastic clip at the middle. Unclip this very carefully as it can break easily, by pinching the clip together and un-locating the teeth (youll know what i mean when you see it)
Hope this helps
