How close is your TIP to the water pipe AUQ
spudboy6
721
114
Swindon
Fitted my TIP And is touching the hard water pipe and no matter what I do I can't get it to clear properly
Its a creation motorsport TIP
they told me the pop can take 200'c so won't melt but surely its shouldn't touch
No photos at the moment but the hard water pipe is touching my tip
spudboy6
721
114
Swindon
Yea I spoke to creation and like you said the pipe won't pass 100'c boiling point and the pipe will take 200'c so will be alright
Just a little curious about the thought of it really
markpile
Wolves till i die!!!!
Mar 15, 2014
434
Wolverhampton
To me it seems bad surely the research these companies do should of indicated this, and if it is touching and the pipe gets hot the silicone will get hot and increase air temp it will also get soft and risk collapse at that point
Oct 15, 2013
926
Midhurst, West Sussex
That's probably why people don't usually like Creations TIP's they recommend the SFS Big bore ones because these companies have designed the parts specifically as opposed to copying other manufacturers
The Creations pipes are a mixed bag as to whether you get a good one or not seems like luck of the draw on most occasions from what I've read from Google etc
jayjaycupra1.8t
93
I have an auq engine and fitted a forge tip to it. Right pain in the a*** to get it in.
mine wouldnt get in with the hard pipe in the way...had to bend it a tad to enable the tip to slide in. No issues with the tip melting or anything
Dave_c85
395
Might not melt the tip but engine vibrations may cause fretting of the tip which isn't desirable really.
Sent from my C6903 using Tapatalk
