Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,014
66
Hertfordshire
Ive got a small problem, iv found a place that do the leads etc and ive bought one with a serial connection but ive not got a new laptop which only has USB ports etc. Now I went to PC world and found a serial to USB converter but it was £30 more than a new lead! Ive now provisionally sold the lead to a friend and want to get a USB one, but all I read is there rubbish and some times don’t work? Now do people mean that theres no advantage of using the usb as its only a converter or that it just wont work correctly?
I bought a USB cable from eBay for use with VAGCOM, and it works fine.
Same situation as you. I previously bought a serial cable for use with an old laptop. New works laptop doesnt have serial, so bought a USB. No problems so far.
or, if you want to keep your serial lead....
i use a usb/serial converter, got it cheap off ebay - there are loads on there.
it's the same as this one: Clicky
Think i got mine second hand for about £10
Thanks, i wont be buying the ross tech one as the price is too much. I know they developed it etc but im a tight arse!
Thanks all i will be getting a USB version then as there only £15 plus P+P!
Where are you gettin yours from? I just bought one 2nd hand for £20!:( And I can't get it to work! :(
I got a usb vag com lead and it only has 5 pins why is this ??? also does this effect the vag com software functionality ??
I Havent Tried It Yet But Will As Sonn As My Laptops Fixed Also Is It Complicated To Use The Software ??
