Horn Wiring Behind Airbag Help
peasie
Can anyone help me with the correct position of horn wires behind airbag got a new airbag and cant remember where the 4 wires go as there are different postions tried a few but horn is staying on help please need sorted for mot,if anyone has a photo or info many thanks steve
mgrays
371
18
Aberdeen
Which connector? there is one to the airbag .. then there is the one to the steering wheel.. and then there is one beyond from the slip ring to the steering column.
Have photos of a Cupra without steering controls.. and for the the yellow one into the steering wheel/slip ring from the airbag/horn... with the tab at the bottom looking from the back of the connector where the wires come out .. it goes from left to right... red (might be brown) air bag, blue air bag, black earth/horn, brown horn. But looking at the slip ring mine has 6 contacts.. so this may not be enough for you.. think the right most last 2 contacts are empty on mine.
peasie
yeah i know which air bag connector is which its the 4 black wires with spade connectors on that work the horn which is puzzled me??
peasie
sorted 4 black wires go 2 on one side and 2 on the other side behind airbag but horn was on all the time stripped it down and the bronze metal plates which make the circuit were bent touching each other causing horn to stay on :)
thanks for replys
