Honeycomb grills
Chriswaite130
Byebye TDI, Hello VTEC y0
Jan 24, 2008
579
Northumberland
Hi all
Just bought honeycomb grills to replace the standard slatted ones on my Sport, just wondering what is the best way to fit them? is it a bumper off jobbie?
AndrewJB
Aug 16, 2007
11,175
485
Maranello
I got mine in without taking bumper off!
What i did was unbolt the bolts under the bonnet at the top ,Pull the bumper forward from the top (Its quite flexible) then we broke the clips from behind because you will find the original ones are glued in.
Once the clips are broken just yank old ones out and pop in the new ones job done
air121005
1,609
Worcestershire
no need to remove or infact loosen any bumper retaining bolts;)
there are 2 plastic retainers on the top / slam panel, which you "ease" up the centre section with a flat bladed screwdriver then pull out the complete clip.
the grill is only then clipped in and should pull out ;)
where did you get a honeycomb grill from anyway, you got a price & link?
Chriswaite130
Jan 24, 2008
579
Northumberland
ah even better! I got the two top ones from Sere motors, £17 for the pair delievered :) but i got the big bottom one from the for sale section for £15!
air121005
1,609
Worcestershire
:doh:..........:think: think i have read your intial post wrong :rolleyes:
thought you were on about the centre top grill.......
however all the other grills are just clipped in ;)
IIRC the fog light grills do have a retaining screw but once the screw is removed, they are just clipped in....
