hollow knocking from front
Dec 3, 2007
2,475
cardiff
right guys. I have a knocking coming from the front of my car. It has a hollow sound to it and it happens when going over bumps slowly or when pulling off right it knocks a few times.
I have searched for the type of sound it makes and other things. My guess would be top mounts but not got time to drop it all and have a look.
I know my car is considerably low but this noise has only just appeared.
Has anyone had this noise before?
Any info appreciated.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
anti roll bar links ok ? should easy enough to get a bar in to find out ?
i get a hollow clunking noise when i reverse off my drive and put the steering to right lock and then again when i drop off the small kerb on to the road.
I had it looked at when i had my steering rack done and they couldn't see anything apart from a bit of play in one of the top mounts. They said wasn't really affecting anything and so far they have been right, haven't been bothered to sort it yet.
Dec 3, 2007
2,475
cardiff
Does it happen when you pull off and also when you stop suddenly? If so I had that on mine and found it to be the lower arm. Bolt needed tightening.
Yeah it does it when pulling off. Cant say i have noticed it when stopping suddenly.
